Network Management
Switch management in Aruba central
I have provisioned a number of 2540 switches into Aruba Central using templates. Is there any way around rebooting the switch each time I make a config change or should we have avoided templates?
We wish to make gradual security updates or simply enable or disable switchports for various needs and a reboot is not possible for each change.
thanks
