Network Management
Frequent Contributor II
System ExecUIQuery failed for 10.X.X.X: 500 Connect failed: con
I am seeing a large number of entries like this one in the event log on my APMs.
Can someone explain to me what this means? everything seems to be working fine but there are too many of these entries to ignore.
Wed May 25 14:46:57 2016SystemSystemExecUIQuery failed for 10.X.X.X: 500 Connect failed: connect: timeout; Operation now in progress.
Re: System ExecUIQuery failed for 10.X.X.X: 500 Connect failed: con
What version of ArubaOS and what AP model?
Colin Joseph
Aruba Customer Engineering
This error is typically when Airwave attempts to login to a controller but has incorrect credentials.
Colin Joseph
Did this ever get resolved?  I have the same problem
ExecUIQuery daemon is for getting PEF application and destination information from the controller when Airwave detects controller is bootstrapped and also for getting on demand clients information when preferred amon VS snmp is enabled.
 If IP addresses in the events are of controllers? then, make sure provide correct credentials in manage page of the controller in Airwave.
pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Thanks Pavan. They are controllers. Is that because I have them set for monitor only mode?
No, check whether controller credentials proivded in Airwave APs/Devcies>manage page is correct.
Pavan
Pavan
