Network Management
Template for switches
I am working on creating a template for my officeconnect 1920 swtiches so i can add them into airwave.  I am adding them in manually and then edit the setting the IP/SM/Mask setting in the node.  I then fetch the config and use the %ip_address%, %subnet%, and %gateway% variables to replace the actual values.  I have copied the data below to show what part of the template looks like that includes those variables.
stp mode rstp
stp enable
interface NULL0
interface Vlan-interface11
ip address %gateway% %subnet%
ip route-static 0.0.0.0 0.0.0.0 %gateway%
However when I apply this template to another switch it applys to a point but leaves out the gateway.  If i was to console into the switch i can see that It has correct IP/Mask and there is nothing for the gateway.
Does any one have any experience in this or see anything wrong with my process. I cant really find much to go on.
Thanks!
