Network Management
Contributor I
The map of RF Plans is offset spatially after upgrading Airwave
Hi team,
The map (background image) of RF Plans is offset spatially Airwave after upgrading from version 7.7.14.2 to 8.0.3.  Because of this, the way to fix it would be to adjust each line, the problem is that too many maps that i use to make plannings of potential customers.
Do you have any advice to adjust the map without it offline by line? Thanks in advance.
Best regards,
Alberto García.
Moderator
Re: The map of RF Plans is offset spatially after upgrading Airwave
Please open a support case to address this issue.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
