Network Management
Tried to upgrade Airwave from 7.7.x to 8.0.x. Stuck at Step 5-Installing Upgrade for a day.
Any help would be appreciated.  Tried upgrade an Airwave Server from OS 7.7.12 to 8.0.7.  For the pass day and a half it has been stuck at Step Five-Installing Upgrade.  I was wondering if there is something I need to do to complete the process.  Thanks...
Re: Tried to upgrade Airwave from 7.7.x to 8.0.x. Stuck at Step 5-Installing Upgrade for a day.
If you have not done so already, please open a support case.  There are a number of reasons why this would fail, and TAC should identify your issue.
