Network Management
[Tutorial] How to Upgrade your Airwave - Offline Upgrade
Hello! in this tutorial i will show you how to upgrade your airwave when:
1-Your server has no internet connection
2-Or when you are like me and prefer doing a offline upgrade( i prefer this because if i do it online something might happen when the airwave is downloading the file) It just personal liking
Anyways lets get started here i ll show you the upgrade from Airwave 7.6.4 to Airwave 7.7.1
This manual assume that your CENT OS is version 6 and not early version
Early versions of Cent OS is not supported in airwave 7.7.1
For more information about that and how to upgrade you can refer here in which Rob explain it!
http://community.arubanetworks.com/t5/AirWave/AMP-7-7-will-discontinue-support-of-CentOS-5-RHEL-5/td-p/57254
First you need to download the upgrade package from the support site
After doing that we need to download a program that let us send that upgrade packiage into the airwave server
The program name is WinSCP
Site where you can download it http://winscp.net/eng/index.php
You download the installtion package and install it...
Really easy to install its next next finish just be careful in installing toolbars :)
Once we got it installed and you open it you will see something like this
Enter your user and password(NOT the web GUI one) use the one you use to log in by console or ssh
The file protocol will be sftp
Click Login
Now we need to transfer the Upgrade package to the root just like you see here!(you just need to drage the file and drop it on the root  really easy and then click copy!
After we copied the file then we need to log by SSH to the airwave
Execute the commandstart_amp_upgrade -v 7.7.1
Now we will need to wait for a while... at least my server is not the faster server in the world so it took around 10 minutes...
After that you will see this
If you get the message of upgrade the kernel well its really explicit just copy and paste the line it says there and you will see this
This will take a while also so dont get scared if it take a while... it was another 10 minutes for my poor server.
After that you need to reboot  executing this command
shutdown -r now
After that we are done
Here is the airwave 7.7.1 :)
Hope it helps anyone.
Cheers
Carlos
[Mod note: edited subject line for readability]
Alternetworks Corp
Moderator
Re: [Tutorial]How to upgrade your airwave(Offline upgrade)
Great article.  Here's another step if you're a fan of keeping download files around and in their own place.
# cd /root
# mkdir upgrades
(upload upgrade packages into /root/upgrades/)
# start_amp_upgrade -f /root/upgrades -v 7.7.1
Then if you ever need to clear some disk space, you'll know that all your past upgrade files are in /root/upgrades instead of /root.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Excellent i didnt know that!
Great Rob!!!!
Cheers
Carlos
Alternetworks Corp
you should also type the command 'screen' before performing the upgrade (if you're doing it remotely).
In case you lose connectivity to the SSH window you can still be logged into the server
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Frequent Contributor I
Re: [Tutorial] How to Upgrade your Airwave - Offline Upgrade
Thanks for the guide. Still a valid step-by-step upgrade process for 8.0.9. I love having it to reference :-)
Quick and nice tutorial
Moderator
Note that post 8.2.4 - these steps need to consider AMPCLI.  Where if you're on Windows - you may need to look into using an SSHD server app like Bitvise, or if Mac - you may need to adjust client ssh ciphers.  We're still looking into ways to make this process easier.
Rob Gin
I am trying to figure out to scp the file over into AWMS, the old way of using winscp isn't working anymore.
Moderator
Correct, you need to setup an SSHD server.  Look into Bitvise SSHD - it's freeware.  You configure it to map /root as some directory on your system, and then the transfer is initiated from the AMPCLI menu.  So if you're choosing upload -> AMPCLI will SSH out to the SSHD server to pull a file.  If you're choosing download -> AMPCLI will SSH out to any SSH client to drop a file.  We're still looking into alternatives to simplify this route.
Rob Gin
