Network Management
Regular Contributor II
Ugrade Aborted 8.2.1.1 to 8.2.6.1
Hi
Upgraded airwave to 8.2.6.1 and now i don´t have cli or webui. I can only ping my airwave Ip address and access the root cli but error states this:
[root@localhost mercury]#
svn: E155007: '/root/svn/mercury' is not a working copy
I know thaat CLI changed but I can´t get airwave up. seems that I am in 8.2.6.1 but no web or cli is working
Any help?
Regards
Moderator
Re: Ugrade Aborted 8.2.1.1 to 8.2.6.1
Did you grab some backups before attempting the upgrade?
I'd suggest opening a support case since that message means something in the post upgrade clean up didn't happen.  It might also mean something else in the upgrade also had issues.  Check /var/log/upgrade/ for the upgrade log.
The message itself is a red herring, not finding root/svn/mercury isn't a problem since the new main code path should be root/git/mercury (the source code repository was changed from svn to git a few years ago).  But the health of the server should definitely be checked out by a support engineer.
8.2.2 is an tested and approved intermediate upgrade step before going to 8.2.6, so if you wanted to by-pass calling support, you could make sure you have a complete backup image, reinstall 8.2.1.1, restore the backup, then upgrade to 8.2.2 before going to 8.2.6.1.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Thanks. I will do that intermediate step.
Regards
Sent from iphone
Bruno Costa
IT Support Specialist
Connecting Projectos e Consultoria Lda.
Rua Diogo de Silves, 33C
1400-107 Lisboa
_____________________________________________
Tel: +351-213031104
Fax: +351-213031117
Movel: +351-916158228
Email: baraujo@connecting.pt
internet: www.connecting.pt
CONFIDENTIALITY - The information in this e-mail and any attachment is confidential and is intended only for the named recipient(s).
The E-mail may not be disclosed or used by any person other than the addressee, no may it be copied in any way.
If you are not a named recipient please notify the sender immediately and delete the email.
this is expected error message
We have moved to /root/git/mercury directory in latest 8.2.x codes,better open TAC case before trying intermediate upgrade steps.
Pavan
If my post address your queries, give kudos and accept as solution!
