Network Management
Contributor I
Update IAP from Airwave results in error and Mitchmatch
Hi
I have just updated 2 groups of Instant ap from 4.2.4 > 6.5.1.5, but after the update the AP is up and running but is in Error.
Configuration:Error (IGC configuration error)
Firmware:6.5.1.5-4.3.1.6_61735
I am not able to select any Policy version 4.2.4 migtate to: the list is emty
Airwave version 8.2.2
I have tried for 2 groups same result.
Is there somthing i have missed
Regards Erik Loeth
Re: Update IAP from Airwave results in error and Mitchmatch
InstantOS 6.5.1.5 is not supported under AirWave 8.2.2 (it supports up to 6.4.4.6) , you need AirWave 8.2.3.x and up
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor I
I did not chect that, sorry my bad.
Thanks for quick a quick reply.
Regards Erik Loeth
Contributor I
Hi
Airwave is now updated to latest but i get the following when trying to access the GUI part
IGC engine is not currently running. It may be disabled. Enable it on the Groups Basic page. The engine may take a few minutes to start after it is enabled.
It is enabled on the grup, so it is not that.
Regards Erik Loeth
Contributor I
OK
I had to restart Airwave then i converted it automaticly but it tok Loooong time to do, so take a cup of coffe (on the other floor).
Regards Erik Loeth
