Network Management
Upgrade AirWave from v7.6.3 to v7.6.4
Are there any guides/manuals to describe upgrading from AirWave v7.6.3 to v7.6.4? I have checked the Aruba Support site and have not found anything that would help with the upgrade. Are there any specific steps to follow for the upgrade?
Moderator
Re: Upgrade AirWave from v7.6.3 to v7.6.4
Two options for upgrading based on network connectivity:
If your AMP can reach the internet, then you can use the automated method:
# start_amp_upgrade -v 7.6.4
This will then prompt you for your support account username and password.
If your AMP can't reach the internet directly, you can use the manual method:
1. Login to support.arubanetworks.com
2. Download AirWave upgrade package from Download -> AirWave -> AMP -> current version -> 7.6.4
3. Upload into /root (WinSCP is a common tool used for transferring from Windows to AMP)
4. Initialize the upgrade
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
MVP
Key point, before initializing the upgrade, change directories to /root so you're not in the directory getting upgraded.
Also, if you're upgrading over ssh, run screen first so a disconnected session won't break everything.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Occasional Contributor I
We had an upgrade issue one time, and we were advised to clear the RRD cache prior to the upgrade.
I don't know that it is neccesary everytime, but I usually clear the RRD cache prior to the upgrade. It's become like rubbing the rabbit's foot.
Clearing the RRD cache
# rm -rf /var/airwave/cache/rrdcached/rrd.journal*
# rm -rf /var/lib/airwave/cache/fastmmap/awrrdtool_write_cache
# service rrdcached restart
Contributor I
Rob,
Why isn't their any upgrade procedures in the documentation, just like it is when upgrading the Aruba Wireless Controllers?  Could this be added?
Moderator
Good idea.  I'll see what I can do.
Rob Gin
