Network Management
Upgrade Airwave from 8.0.10 to 8.2.3
Hi, All
We have OV3600 running on 8.0.10 and now we need to upgrade to 8.2.3. I found useful links in this but not sure is some of the steps still apply. The thread was few yrs back.
http://community.arubanetworks.com/t5/Network-Management/Tutorial-How-to-Upgrade-your-Airwave-Offline-Upgrade/td-p/85634
http://community.arubanetworks.com/t5/Wireless-Access/AMP-7-7-will-discontinue-support-of-CentOS-5-RHEL-5/td-p/57254
We were also given steps on how to upgrade but not sure on the Airwave server AMP.
I am also not sure if my CentOS need to be upgraded before I can upgrade to 8.2.3.
Output from our OV3600. Can I directly patch to 8.2.3 using the CentOS6.6 below?
[root@OVManager mercury]# cat /etc/redhat-release
CentOS release 6.6 (Final)
[root@ODC02OV01 mercury]#
Jun
Re: Upgrade Airwave from 8.0.10 to 8.2.3
You can upgrade directly.  You don't have to upgrade CentOS manually.
The instructions here:  http://community.arubanetworks.com/t5/Mobility-Hero-Tutorials/How-to-Upgrade-your-Airwave-Offline-Upgrade-Jul-2013/ta-p/145703 are still valid.
I would make sure you have a nightly backup or do a manual backup, just in case...
Super Contributor I
Is 8.2.3 out? Can´t find it on the support site.
Cheers,
Christoffer Jacobsson | Aranya AB
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
The latest currently is 8.2.2.1
Sorry for the confusion guys, I was just way ahead of my self. Scheduled OS released will be this Nov 2016. My boss just ask me to prepare.
Thanks for all the feedback.
