Network Management
Upgrade firmware on a single AP in a cluster using AirWave
We have a bunch of IAP205's managed by a single VC and configured as a single group in AirWave. Is there any way I can upgrade the firmware on a single AP to verify that it works before upgrading the rest?
Uploading a new FW to AirWave and the trying to upgrade a single AP in the cluster by going to 'APs/Devices' -> 'Modify Devices' -> 'Upgrade firmware for selected devices' doesn't work. It just gives me "None of the selected devices can have their firmware upgraded."
Trying to upgrade from to Tried to go to as well with the same result.
