Network Management
Upgrade nightmare from 7.5.5. to 7.6.3 for Airwave and Failover Airwave
So this morning, I was tasked to upgrade 2 Airwave servers (1 of them acting as the failover).
These Airwave servers contain massive amounts of data, the backup of the primary is >5Gb
This is what happened to me (doing upgrades remotely but they are hosted at our datacenter and we have a fibre connection to the datacenter)
1. Upgrade the backup to 7.6.3 (works)
2. disable the backup (amp_disable now)
3. Upgrade the primary to 7.6.3
                 Lost internet connectivity in the office, my SSH session during the upgrade dies
4. Upgrade never completes on the server, it is practically missing everything
               doesn't understand start_amp_upgrade, amp_version, that directory is empty
5. try to restore the backup on the failover, problem is its already been upgraded to 7.6.2 so backup won't restore
6. Airheads and KB searches later
7. I move amp_enable, start_amp_upgrade, amp_version and chmod a+x the files
8. try the upgrade again, fails, doesn't complete. fails on /bin/chown -R apache.apache /var/airwave/rrd
                       we have about 1TB of RRD data on the server
9. I see Sujatha's post regarding make, I see another from Rob's (rgin) regarding make, so I try it (root; make)
10. it puts back certain files and allows me to execute the upgrade again and now it is stuck on
                  STEP 5: Installing upgrade.
   tail -f /var/log/upgrade/AMP-7.6.3-upgrade.log
Won't go further than that.
its been 4 hours now, maybe I should have called TAC ......might have to go with the 5Gb backup file to DC to re-install the primary AIrwave from scratch
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Re: Upgrade nightmare from 7.5.5. to 7.6.3 for Airwave and Failover Airwave
So more on this...at the datacenter that same day at 830am, tried to re-install AMP using a bootable USB key but not working at all. On the phone with TAC, finally was able to get an external CDROM drive, re-installed AMP, restored my 5Gb backup (took 1.5 hours to restore).
Got it up and running at 4pm.
Ever since then it has been behaving really oddly, no AP down alarms come in but a constant wave on controller downs non stop, therefore I don't receive AP downs as the controller is "down" according to AMP. Like below.
Device UpDevice Type is Controllerwlc-6.tdl.c6.dv3/25/2013 8:08 AMNormal-
Device DownDevice has rebooted: Device uptime value changed (current: 497 days 2 hrs 27  (more...)wlc-6.tdl.c6.dv3/25/2013 8:08 AMCritical
Why??? I don't know..
Increased the monitoring processes from 6 to 10 last night, still not performing correctly.
We upgraded the controllers to 6.2.1.0 the same night as I upgraded AMP. AMP still has not seen or updated the uptime for more than of my 1/2 of my controllers....
AMP is monitoring a network of 28 controllers and >2000 RAPs...version 7.5.5. now
My TAC guy is only available on Tuesday to help me so I am here looking for help :).
ACDX #420 | ACCA
I remember now that TAC had applied a patch to my airwave server to fix a snmp trap issue.
My AMP cannot snmpwalk my controllers.
I found the file they used but to apply it I do not seem to remember the commands.
ACDX #420 | ACCA
found out how to apply it, applied patch
patch -p0 < /var/airwave/custom/file.diff
root; make
I still cannot snmpwalk the controllers
[root@aw-1 mercury]# snmpwalk -c tdl_prod$c6 -v 2c 172.30.128.66
Did not find 'InterfaceIndex' in module ARUBA-TC (/usr/local/airwave/share/snmp/mibs/aruba-trap.my)
Timeout: No Response from 172.30.128.66
Going to go try and upgrade it to 7.6.3 today directly on the box at the DC
ACDX #420 | ACCA
Moderator
patching commands:
Test patch:
# patch --dry-run -p0 < /var/airwave/custom/patch.filename
#### If patch runs clean without complaints, then remove dry-run ####
Apply patch:
# patch -p0 < /var/airwave/custom/patch.filename
# root; make
General tip:
For a setup that has an AMP and Failover, I typically run #amp_disable on the Failover, then run through the upgrades on the AMP.  Once the AMP is completely upgraded and back online, then I run through the upgrades on the Failover.  If I have 2 AMPs, then I'd run through upgrades on one completely, and then the other.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
thanks Rob, I was told backup first then primary....noted for next time...:)
for some reason, I don't know why it cannot snmpwalk the controllers, I used a backup and restored it and te backup was 3 days old at the time..
ACDX #420 | ACCA
Moderator
You were probably told to do the backup first since it's non-critical, and a quick upgrade since there's no database migration.  You can really do either or, but as a habit - I typically disable the Failover so that it doesn't try to take over while I upgrade the main AMP.
As for your snmpwalks not working, check the RPMs that are installed:
# gr snmp
These are the packages for SNMP that should be present:
aw-erlang-snmp-R14B-04.2.x86_64
aw-net-snmp-aw-5.5-10.x86_64
aw-net-snmp-aw-perlmods-5.5-10.x86_64
aw-perl-Net-SNMP-6.0.1-3.noarch
perl-SNMP_Session-1.12-4.el6.noarch
If you're not seeing a package, you can install them from:
/root/svn/mercury/src/noarch/rpms
/root/svn/mercury/src/x86_64/rpms
Rob Gin
snmp is installed, its just that it won't walk the controller I get an error message (shown in previous post).
I am upgrading the server now to 7.6.3 so hopefully this fixes all my issues. Keep you posted.
I just wanted to share my experience regarding the upgrade that didnt go right. Still love Airwave ;)
ACDX #420 | ACCA
Upgrade Success! but....Airwave still cannot snmpwalk my controllers...so odd.
I get a timeout
AMP and controllers are on the same subnet, no FW rules or ports blocked...
ACDX #420 | ACCA
Moderator
It could be that the request is too large.  Try doing a shorter SNMP request like:
# snmpwalk -c public -v 2c 10.10.10.10 sysDescr
# snmpwalk -c public -v 2c 10.10.10.10 sysName
I think having the OID in there might make a difference.
Rob Gin
