Network Management
Contributor II
Upgrade path from Airwave 8.0.11.1 to 8.2.2.1
What is the upgrade path from release 8.0.11.1 to  8.2.2.1?  Can I upgrade it directly? Are there another important considerations about licenses or others topics?
I can´t find in the release notes.
Regards
EF
Re: Upgrade path from Airwave 8.0.11.1 to 8.2.2.1
Typically only an upgrade from 8.0.x.x to 8.1.x.x are supported in Airwave.  That is the safest path.
Contributor II
I´m sorry but about this path "8.0.x.x to 8.1.x.x ", I think you made a mistake because there isn´t any release 8.1 available for download.
Go directly to the 8.2.  My mistake.
Contributor II
Update from 8.0.11.1 to 8.2.2.1 directly without problem.
