Network Management
Using Airwave to upgrade to a c-Build image
I have a c-build I want to install and I want to push it with Airwave. However the imave version matches the current installed version, so Airwave upgrade image doesn't see it as an available upgrade.
How can I get around this?
(Image names have been left out to protect the innocent)
Re: Using Airwave to upgrade to a c-Build image
Unless the files have been altered in some way, they should normally work regardless of release versus c-build status.
A regular build from AOS off the support looks like:
(firmware type, device, firmware version, firmware build)
Whereas a c-build might look like:
C_ArubaOS_MMC_6.1.3.5_99999 (not a real build, just an example)
The key is to not strip the filename of the build number when importing the firmware into AMP.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
