Network Management
Using Aruba Central with Extreme Controller V2110 AP 3805, 3020
Hi.
I'd like to know if it is possible to use Aruba Central fo a WLAN based on  Extreme Controller V2110 and Extreme AP 3805, 3020 , and if it is ok, if there is any restrictions.
Thanks!
Mario Pires
Re: Using Aruba Central with Extreme Controller V2110 AP 3805, 3020
That's not possible , you can only manage Aruba instants and AOS switches
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect
