Network Management
Virtual Controller Assigned IP addresses not NATing
Virtual Controller Assigned IP addresses not NATing.  The internal assigned subnet of 172.31.98.0 is not being NATd to the Virtual Controller IP as it should. This is on a Guest Defined SSID. I am running 6.5.4.7
Regular Contributor II
Re: Virtual Controller Assigned IP addresses not NATing
Hi
On which type of AP?
Did you assign the subnet manually or are you using the magic VLAN, aka virtual controller assigned default?
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
