Network Management
Visual RF - Is there a reason that Visual RF Plan 8.0 RC1 does not allow adding single .dwg file
Just upgraded from an older version of Visual RF planner I have been using since quite a while. It had issues since I could not unlock certain floorplans.  After installing v8, with the new browser based "GUI", I lost a lot of menu items and the import does not allow what was in the +Add floorplan menu earlier. As a result I cannot import floorplans at all (well I did not try the xml version- but I doubt the idea with the upgrade was to make it useless to all but programmers)
Moderator
Re: Visual RF - Is there a reason that Visual RF Plan 8.0 RC1 does not allow adding single .dwg file
[ Edited ]
Your question here is a bit different from what you posted internally.
The latest VRF Plan update mirrors the current visuals from the 8.2 AirWave release.
If you drill down to the building level, you have 2 ways to add a floor plan:
1) right click to see 'new floorplan' option
2) on the right hand menu go to the edit tab and choose 'new floorplan'.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
But the add floorplan option never appears...
Geir
Moderator
What browser is your VRF Plan launching in?  If it's Win10 w/ Microsoft Edge browser, we have not seen it work yet.  But it should work with Chrome or Firefox.
Rob Gin
Firefox - I installed Airwave - that works - but I cannot give that to the partner just like that.
Geir
Geir Leirvik
[hpe_pri_grn_pos_rgb]
Network Technologist
HPE Aruba
Norge/ Norway
Phone: +47 41 72 40 30
E-mail: gleirvik@hpe.com
