Network Management
Occasional Contributor I
Visual RF
How can we successfully load a floor plan on visual RF and get to know if the maps are working fine?
Re: Visual RF
Do you have access points on those maps?
Re: Visual RF
Yes it does have access points.
Monica
Re: Visual RF
Did you follow the instructions here?  http://www.arubanetworks.com/techdocs/AirWave_8_0_Web_Help/UserGuide.htm#AWUserGuide/Chapter9_VisualRF/VisualRF.htm%3FTocPath%3DUsing%2520VisualRF%7C_____0
