Network Management
VisualRF BoM export not working
I'm having a problem with VRF not exporting the BoM, backup zip works fine. It all used to work, recently upgraded my entire platform from Win 7 and Office 2010 to now Win10 Office 2013 VRF version 7.7
I'm assuming its a application issue with Java or MS Office, not allowing VRF to open the Word.
I searched and did not turn up any results, does anyone have any advice? I cannot go back to the old setup.
Thanks! Marc
Re: VisualRF BoM export not working
So this is for VisualRF Plan (standalone tool)?  If so, can you please post the full versioning from the 'about' section that shows version, build date, build, and VRF data path?
For instance, mine shows as:
Version: 7.7.rc1 (build: 454)
Build Date: 2015-01-15 10:48 PST
Java Runtime Version: 1.6.0_22
VisualRF Engine Version: 7.7.0
VisualRF Engine Build: 87613
VisualRF Engine Database: 80766
VisualRF Data Path: C:\Users\rgin\visualrfplan
VisualRF Plan Static: 87613
If this is not VisualRF Plan, but the VisualRF within an AirWave setup, please provide the full versioning form the command line output of: # root; svn info
[root@airwave mercury]# root; svn info
Path: .
Working Copy Root Path: /root/svn/mercury
Repository Root:
Repository UUID: 99f6a4a8-5413-0410-a0fb-e6b940866760
Revision: 98020
Node Kind: directory
Schedule: normal
Last Changed Author: sameer
Last Changed Rev: 98018
Last Changed Date: 2016-02-18 21:00:50 -0800 (Thu, 18 Feb 2016)
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
OK here is what I've got, Yes VRF standalone tool.
VisualRF Plan Version: Build Date: Java Runtime Version:   VisualRF Engine Version: VisualRF Engine Build: VisualRF Engine Database: VisualRF Data Path: VisualRF Plan Static:
7.7.rc1 (build: 473)
2015-10-27 15:10 PDT
C:\Users\Marc\Documents\Aruba RFPlanner
Java Version 8 update 73 build 1.8.0_72-b02
I have tried in my test environment with same build on windows 7 system and looks like its not working. Its not a known issue. Please open a TAC case.
