Network Management
VisualRF and client usage data
We recently started using VisualRF to track our wireless coverage and I'm wondering whether it's possible to add usage data to this. Specifically we're interested in a map that visualizes data similar to what is provided in the Device Summary report. Ideally an overlay that shows which APs have the most usage.
I'm thinking the solution will be to export the report data to Excel but I figured I'd ask in case anyone has some ideas on how else to visualize those numbers.
Thank you in advance!
AirWave 8.2.1.1
Re: VisualRF and client usage data
Hi ,
In visualrf we could see application usage of associated clients but not total usage of APs. We have client overlay and AP overlay, in clinet overlay we have option to see client APPRF and UCC data but for AP we see only channel , channel utilization and voice.2.5.PNG
Pavan
If my post addresses your query give kudos:)
Pavan
If my post address your queries, give kudos and accept as solution!
Thank you for your reply and confirming this :)
PAVAN wrote:
Hi ,
Pavan
