Network Management
VisualRF not show Client
  • 1.  VisualRF not show Client
    Posted Jun 06, 2017 04:30 AM
    Hi everyyone
    I found problem with my Airwave,
    it could not show client in VisualRF but Heatmaep and AP are show.
    I tried to see in "List" , it show client is "0" also.
    So How i can fix ? my current version is 8.2.4.
    Thank you for your kindly.
  • 2.  RE: VisualRF not show Client
    Posted Jun 06, 2017 04:46 AM
    Hi Jate,
    Are you seeing this issue after upgrade? Only on VisualRF floor plan we are not seeing clients or even in Airwave ?
    Try poll the VisualRF database
    https://<server ip>/visualrf/poll_aps_now.xml
    Pavan
  • 3.  RE: VisualRF not show Client
    Posted Jun 06, 2017 04:58 AM
    Hi Pavan
    This issue occure before upgrade , I thought it's bug if I upgrade it should work.
    But actualy it's still problem after upgrade.
    Airwave can see all clients in menu "Clients" , see username , IP and every infos of clients.
    But only clients in VisualRF, it's not show clients.
    SIncere.
  • 4.  RE: VisualRF not show Client
    Posted Jun 06, 2017 05:39 AM
    Did you try poll the visualrf database and checked the status?
    Pavan
  • 5.  RE: VisualRF not show Client
    Posted Jun 06, 2017 05:47 AM
    Pavan
    OK
    <results>
    <success>AP Poll successful</success>
    </results>
    Sincere.
  • 6.  RE: VisualRF not show Client
    Posted Jun 06, 2017 06:03 AM
    Jate,
    You might have done this, however just to confirm could you please check whether the client option is checked under the views on Visualrf floor plan?
  • 7.  RE: VisualRF not show Client
    Posted Jun 06, 2017 06:09 AM
    Sorry i over read it. Didnt notice the part where you mentioned that you see 0 clients under Network --> Properties.
    Have you tried restarting Visualrf engine? You can set Enable VisualRF Engine: to no under setup page, wait for 5 to 7 minutes and enable it again.
    If you are still seeing the issue i would request to open a TAC case.
  • 8.  RE: VisualRF not show Client
    Posted Jun 06, 2017 06:13 AM
    Hi Vishnu
    Yeah I tried to dis/en VisualRf and also reboot, still problem.
    Sincere.
  • 9.  RE: VisualRF not show Client
    Posted Jun 06, 2017 06:15 AM
    Hi Jate,
    Thank you for the update. You can drop me an email to mannil@hpe.com i can take a look at the server.
