Network Management
Regular Contributor II
VisualRF on tablets/touchscreens?
I'm curious if anybody is using VisualRF on a tablet or touchscreen device with any success?
I've tested on a few older Android tablets (4.1.2 and 5.0.1) and on a touchscreen PC running Windows 7 - neither will allow me to operate many functions within VisualRF.
I can't  seem to double-click to open a site/building (although on Android this seems to work if I long press), and am not able to draw walls.  I can draw walls on the PC with the mouse, but not on the touchscreen.
I don't have access to any newer devices to see if maybe this is a limitation with Windows 7 on a touchscreen and might possibly work on Win8 or 10, or on newer versions of Android.
I spend quite a bit of time using VisualRF and using a mouse can cause some CTS problems.
I imagine marking up floor plans might be easier if drawing on a tablet or touchscreen, or maybe I need to look into a pen input device for my PC?
Anybody out there have experience with any of this?
Re: VisualRF on tablets/touchscreens?
I used to use VisualRF on my Surface Pro with the Surface pen all the time.
Was great for drawing walls, etc.
Tim Cappalli | Aruba Security
Moderator
Instead of drilling down by double-clicks, I tend to use the 'list' navigation to jump to a floor plan.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
