I have a problem with the encryption command 'user WDSUser NTHash 7' of WDS.At the moment I have a template with many AP, in the template I created the variable conditional WDS to client to master or backup.
When I pass the AP monitor to manage appears Mismatched as WDSUser besause the user password does not match.
I tried to put a incriptacion of 0 but it changes and encrypts it, but I also tested the AP <ignore_and_do_not_push> but the AP shown mismatched with the current command.
How I can solve this issue?
Thank you very much
Regards
