While apache is running, you only have low_level_service_watcher, the other daemons didn't start. Few things to check:
1) server sizing: disk space, memory allocation
2) /var/log/low_level_service_watcher
3) /var/log/service_watcher
My guess is that it hasn't gotten far enough for service_watcher to start, so there might not even be a service_watcher log. This usually happens on undersized setups. Keep in mind that on a fresh install, the processes should start up roughly 7-10 min after the installation completes.
