Network Management
What license should i get for Airwave to monitor Devices less than 25
I need to monitor/manage 12 IAP which license should i get for Airwave?
can i just get 12 x LIC-AW?
or i need to get the bundle AW-25 first?
Re: What license should i get for Airwave to monitor Devices less than 25
Yes, you can simply get 12x LIC-AW.
Tim Cappalli | Aruba Security
Thanks you,
hmm when i do the calculation
it seen like 25 x lic-aw is cheaper than AW-25
is there a limit for LIC-AW to be added in ?
I'm not sure I understand your question.
Sent from Nine
as in if i buy 25 x lic-aw the pricing is cheaper than  1x aw-25
so i am not sure if there will be a limit/threshold i can add lic-aw
You can buy licenses as you need them as part of the new additive licensing model.
Be sure to also purchase support so you can receive updates and TAC assistance.
Sent from Nine
Hi cappali,
Noted with Thanks :)
