i need answer for the following scenario,
when instant group being managed by airwave server , by default access to the virtual controller gui will be limited and applying changes to the settings will not be possible , what will happen to the instant when the airwave server will go down , and the instant determine that the airwave server is down .. ?
does the instant VC local gui will be avilable for settings modifications ?
are the IAPs will do reboots?
The Instant primary device sends an update message to AirWave every minute. If the send fails, then the device will continue to send a state message every two seconds. If the send fails 25 times, then Instant will determine that AirWave is down."
