Network Management
Contributor II
Wireless network daily reboot
we have a customer with a controller Aruba 650. He is asking us to plan a daily reboot of the wireless network.
Is it possible to do it and how?
Thanks.
Best regards!
Re: Wireless network daily reboot
There is no command that can do that in ArubaOS today.  Why does the customer want the daily reboot?
Colin Joseph
Aruba Customer Engineering
Contributor II
Thank you for the answer.
I think there aren't good reasons to do that, but they keep asking it, because recently they have many problems with the network, included the wireless. With the wireless network they mainly complain frequent clients disconnection.
You should never have to need to reboot the controller. If they are having problems with the wireless, that should be troubleshot.
Colin Joseph
