Network Management
Won't communicate using cable internet
I have a 7005 controller connected to cable internet service with a static ip. Once configured I cannot ping to the Internet, however, when I configure the same static ip on my laptop and connect to the cable modem it works. Any ideas, I'm completely at a loss; everything seems to be configured correctly. I have verified the ip, subnet mask and default gateway.
Re: Won't communicate using cable internet
Did you reboot the cable modem?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
I have tried just about everything.  I configured the assigned static IP on my laptop then connected to the cable modem, had the provider clear arp on the modem and it then worked.  On my controller I performed a write erase and then started over, accepted the defaults for VLAN 1 and then created VLAN 2, assigned the static IP to interface VLAN 2, then assigned interface Gi0/0/3 as an access port in vlan 2; no luck.  I ensure my default gateway was set correctly.  I connected between my laptop and the controller interface and it works okay.  Everything seems to work except when I connect the controller to the cable modem.
Can you ping your default gateway?
Cannot ping my default GW.  See the attached running config from the device.
I've continued troubleshooting this problem.  If I put a small switch between the cable modem and my controller (7005) it will work.  Whenever I have my controller directly connected to the cable modem no good; I'm not seeing anything in the ARP table.  Do you think an OS upgrade or possibly downgrade could make a difference?  I'm running version 6.4.3.9.  This problem presented at another location the other day, same controller model and OS (7005 running 6.4.3.9).  Thoughts??
Is it possible that you are using a crossover cable?
Nope, definitely have a straight through cable.
Today I had the ISP go to the site and replace the cable modem.  Recap of problem:
Arubal 7005 controller running ver 6.4.3.9 connected to cable internet service from Cox Communications (cable modem was a Cisco DPC3021).
Nothing seemed to work when connecting the controller to the cable modem, after much troubleshooting as best as I can tell, it appears to be a hardware compatibility issue between the Cisco DPC 3021 and the Aruba 7005.  Whenever the ISP (Cox Business) replaced the Cisco cable modem with a Motorola/Arris Surfboard 6183 it immediately came up and started working.  Prior to that, the only way I could get it to work was to put a small switch (i.e. Linksys or something) between the two devices.
I have the exact same problem at another site (also exact same hardware involved); I have the vendor scheduled to replace the cable modem there also.  I feel relatively certain this will fix the problem there also.
