Network Management
accessing web interface
I am trying to connect my management laptop to an Aruba controller. The controller port is on DHCP, I have connected this laptop before and was able to enter the IP of the controller and access the web gui.
However when I do this now, the webpage comes back with saying the certificate was revoked. I did used to have to press "proceed anyway" but now that option has disappeared, any ideas?
Thanks in advance
Re: accessing web interface
Please read about the whole issue here:  https://community.arubanetworks.com/t5/Controller-Based-WLANs/ArubaOS-Default-Certificate-Revocation-FAQ-Controllers/ta-p/275809
Long Story short, you can try to get into the controller with a different browser, but you will have to change the Management Certificate afterwords to avoid the revoked certificate issue.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
