Network Management
adding Aerohive AP's into Airwave
i want to add Aerohive Aps into Airwave management....it there a way to do this.
Re: adding Aerohive AP's into Airwave
They're not in the list of supported devices. You might be able to add the devices and get basic monitoring working. E.g. is it Up / Down
Cheers
James
-------------------@whereisjrw-------------------
------------------------blog-------------------------
