Network Management
airwave AP groups - duplicate APs
We are using Airwave For some reason when I'm under visual RF, I am seeing multiple APs with the same name. When I go to APs I do not see any of the APs being duplicated. I would like to clear the duplicates. How do I do this?
Re: airwave AP groups - duplicate APs
My first run at this would be to disable VisualRF, wait 5 minutes, then re-enable.  This action should force VisualRF to recheck the APs available to list for provisioning.
Alternatively, you can open a support case to see if there's another way to perform the device check.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
