Network Management
airwave virtual appliance
Can I Install airwave on a virtual appliance like Vmware ..... System specification for that as i only see hardware appliance in IRIS.
Re: airwave virtual appliance
Yes.  You can use the Airwave Sizing Guide ASE Solution here:  https://ase.arubanetworks.com/solutions/id/77
Colin Joseph
Aruba Customer Engineering
We generally recommend 20% more resources allocation for Airwave installed on Virtual machine compare with the physcial server sizing recommendations.
If you have problem in accessing the Airwave sizing guide site, let me know below details, I could provide the recommeded sizing
  • Number of  Aruba devices monitoring
  • Number of wired devices
  • Number of VisualRF floor plan uploading to Airwave?
  • Does Report demand is high or low?
Pavan
If my post address your queries, give kudos and accept as solution!
Moderator
Keep in mind that we do post an OVA image of AirWave.  This image is specifically created to work with VMware.  By default, the posted image will load with the following specs: 4 core, 8 GB RAM, 80 GB disk.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
