Network Management
airwaves not detecting clients
  • 1.  airwaves not detecting clients
    Posted Feb 04, 2013 11:45 AM
    Hello
    Im testing the lastest verison of airwaves...
    I got it with my demo Wireless controller whichi s also with the lastest firmware...
    I set it up, and i can see everything, rogues aps the APS the wireless controller all with config good no mismatches.
    But my airwaves says there is 0 clients connected when i got like 3 connected... i already did polling but stilll cant see them on the airwaves?
    Any help will be appreciated.
    Cheers
    Carlos
  • 2.  RE: airwaves not detecting clients
    Posted Feb 04, 2013 02:44 PM
    A few quick things to check:
    Besides device model and firmware,
    1. Are the APs added in AMP?
    2. Has the SNMP string been changed?  If so, does AMP's SNMP string for a controller match up with the controllers enabled SNMP strings?
    3. Try SNMP walking the OIDs: nUserName, nUserRole, nUserApBSSID.  If you have 3 clients, you should be getting 3 returns on each topic.
    4. Are these wired or wireless clients?
  • 3.  RE: airwaves not detecting clients
    Posted Feb 05, 2013 06:18 PM
    Hello Rgin!
    Re: airwaves not detecting clients
    Yes
    Yes otherwise i dont think they would be up on my Airwaves i think
    How do i do this?
    They are wireless Clients
  • 4.  RE: airwaves not detecting clients
    Posted Feb 05, 2013 08:38 PM
    The AMP CLI has some aliases that assist with SNMP walks.
    For SNMP v2c:
         # s2w (IP address of controller) (community string) (OID string) (additional flags)
    Example:
         # s2w 10.10.10.10 public nUserName
    Example with flags:
         # s2w 10.10.10.10 public nUserName -OX -Cc
              -OX = translates hex values to mac if available
              -Cc = makes sure to walk OIDs in increasing order (to escape loops)
    For SNMP v3:
         # s3w (AMP database ID for controller) (OID) (additional flags)
    AMP database ID can be gotten from the URL of the controllers monitor or manage page.  It will be the ending value of the URL.  For instance, if my URL was: my.amp.name/ap_monitoring?id=15813
         Then my ID is 15813.
    This will merely confirm what data the controller passed to the AMP via SNMP.  Pay attention to response time, a slow SNMP response from a walk is going to be the same when AMP makes the request.  Also, if the table is large, you may want to time the amount of time it takes to get the complete response (In the case of AMP's request, the actual request is for the entire table, not just the single OID, so walking 'wlsxUserTable' would be closer to the actual.  I had provided the individual OIDs as they get the specific data to look at out of the table).
    If the SNMP walk yields the correct response, then the next step would be to open a support case.  Provide the controller firmware version and the data collected via SNMP walk.
  • 5.  RE: airwaves not detecting clients
    Posted Feb 06, 2013 05:29 PM
    Thanks Rgin! ill try these this week!
    ill have you updated!
    But its weird becasue i had a demo on an older firwmare of Airwaves and everything worked just fine...
    This time i build a new Virtual Machine and added it in the same way i did before but with the other airwaves, and now i got this problem!
    Cheers
    Carlos
  • 6.  RE: airwaves not detecting clients
    Posted Feb 06, 2013 05:37 PM
    Remember when monitoring Aruba devices to have the traps also pointed as some updates are triggered faster by traps:
    On the controller:
    # snmp-server host <AMP IP ADDR> version 2c <SNMP Community String of Controller>
  • 7.  RE: airwaves not detecting clients
    Posted Feb 06, 2013 05:38 PM
    Yes i got that configured already, its on the manuals i read :) hehe
     snmp-server host 172.16.3.222 version 2c xxxx udp-port 161
    mgmt-server type amp primary-server 172.16.3.222
    I got those on the controller
  • 8.  RE: airwaves not detecting clients
    Posted Jan 23, 2015 06:40 AM
    it is just a POC,may i still open a CASE also?
  • 9.  RE: airwaves not detecting clients
    Posted Jan 23, 2015 08:43 AM
    if you have a support contract, yes you can open a case
  • 10.  RE: airwaves not detecting clients
    Posted Jan 23, 2015 09:07 AM
    Look, It's just a POC to our potential customer. So, no support contract from our potential customer.
  • 11.  RE: airwaves not detecting clients
    Posted Jan 23, 2015 09:17 AM
    I suggest speaking to your SE then at that point.
  • 12.  RE: airwaves not detecting clients
    Posted Jan 23, 2015 09:52 AM
    just talk to me directly,  i am a pre-sales  SE, I am supporting  that POC bymyself now. you can see my eamil in my account,right?  Thx
