Network Management
Contributor I
appRF, webCC and DPI
Hi All,
I know that is basic, but just to tie everything together:
DPI: the visibility to examine packet's data portion and even the headers, and it's mandatory for appRF.
webCC: to extend Aruba's application visibility, classification and control features.
appRF: an application visibility and control feature use both of them to build application-based session ACL.
can I build appRF without webCC, I think yes but for specific application, but with webCC I can extend the control per application category.
please correct me, and your input is highly appreciated, thanks in advance
Re: appRF, webCC and DPI
see here http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Content/ArubaFrameStyles/Dashboard_Monitoring/AppRF.htm
#AirheadsMobile
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
