Network Management
Contributor I
clear pass bandwidth limitation ,,,, how ?
does any one have a document for bandwidth limitation using clear pass ?
Re: clear pass bandwidth limitation ,,,, how ?
Can you explain what you're trying to do in a bit more detail?
Cheers
James
Contributor I
i need to limit the usesr not to exceed 50 MB download daily using clear pass , they are wireless users on aruba controller .
That's accounting, google will be your friend. ClearPass will work, but which switches are you using?
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
