Hi community:
My current deployment has 2 physical AMP's and a Master Console in a virtual enviroment on the cloud. I want to add more security, so I am planning to add a firewall between 2 AMP's and MC. So, Which communication ports are used?
Regards
Karlink
you can this info on the Airwave server.
Go to Home - Documentation
Download the installation guide and check the section "Configuring and Mapping Port Usage for AMP"
Hi Borja:
this information is complete only for AMPs I think, which ones are dedicated only for communication from Master Console and AMP.
