Network Management
dumb question / airwave upgrade
  • 1.  dumb question / airwave upgrade
    Posted Apr 24, 2014 12:02 PM
    Looking to upgrade our install of airwave from 7.7.8 to 7.7.10.
    When I kick off this upgrade it will NOT impact wireless services correct?  Airwave is configured just for monitoring not config at this point.
  • 2.  RE: dumb question / airwave upgrade
    Posted Apr 24, 2014 12:23 PM
    It should not impact your wireless connection since you are only monitoring your devices.
  • 3.  RE: dumb question / airwave upgrade
    Posted Apr 24, 2014 02:14 PM
    Have you configured WMS offload?
    Even if you have, don't expect any noticable outage, just be aware that that function will be on hold while you upgrade. I've been through many upgrades with no impact -- monitoring with software upgrade and WMS offload.
  • 4.  RE: dumb question / airwave upgrade
    Posted Apr 24, 2014 02:19 PM
    Offload WMS database is not enabled.
    Out of curiosity what does that do?
  • 5.  RE: dumb question / airwave upgrade
    Posted Apr 24, 2014 02:52 PM
    I can copy and paste it from the help in Airwave, but if you just search  the help in Airwave for WMS Offload, there is a section explaining it.
