Network Management
Occasional Contributor I
how to add unknowns SysObjectIDs in Aruba Airwave?
How to add unknowns SysObjectIDs in Aruba Airwave?
I am using Huawei WLAN controller to integrate with Airwave. Huawei devices are not present in Airwave supported device list. So i added this as a custom device. Its showing me "unknowns SysObjectIDs: in event logs.
Please help me to find a solution.
Moderator
Re: how to add unknowns SysObjectIDs in Aruba Airwave?
Unless they use the generic MIB-II OIDs, we might not be able to see any data unless device specific coding is added to map out their MIB tables.  Has a feature request been submitted yet?  That's the best route if adding universal network device doesn't do the trick.  Be sure to include device type, model, firmware version, and an SNMP walk of the entire OID table.  From there, the Product team will review.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
