Network Management
Frequent Contributor I
how to configure a template in Airwave so that it will not show a missmatch for an encrypted psw
I am adding a number of autonomous AP's into airwave and have a number of passwords in each config that will be encrypted so they come out different.   this will mark the device as a missmatch.   how do I set up the template to not look at this to be an issue.
I have looked at the documentation about modifying the templates but not sure how I would make this into a variable or some such.
