Network Management
how to get backup in CPPM AND AIRWAVE?
Hi  All,
I am using airwave 8.2.1.1 and CPPM 6.6.2.8
I just wanted to know that how to take backup config file from Airwave? and CCPM?
Thanks in advance.
Re: how to get backup in CPPM AND AIRWAVE?
For ClearPaas, go to Server Configuration, click the radio button next to the server you want to back up and click "Backup".
Tim Cappalli | Aruba Security
Thank you so much for your quick response and what about airwave please?
From the Airwave user manual:  http://www.arubanetworks.com/techdocs/AirWave_8_0_Web_Help/UserGuide.htm#search-backing up airwave
From the ClearPass User Manual:  http://www.arubanetworks.com/techdocs/ClearPass/Aruba_CPPMOnlineHelp/index.htm#CPPM_UserGuide/Admin/ServerConfig_backup.htm?Highlight=backup
thank you so much i got it.
After the daily backup is setup you can download backup files from System-Backups.
