Network Management
Occasional Contributor I
management users (mgmt-users) create modify roles privileges (is it possible ?)
is it possible to add managment roles other than  the built-in in the controller, and modify them ?
root
guest-provisioning
network-operations
read-only
location-api-mgmt
Aruba
Re: management users (mgmt-users) create modify roles privileges (is it possible ?)
No, you cannot create new roles or customize the built-in ones.
AMFX | ACCX | ACDX | ACMX
