Network Management
ms-chap airwave management authenication using 2008 nps
Hello!
Is there an update to date guide on setting up management access using ms-chap via 2008 nps, i've tried to get it working using an older guide which is pre-ms-chap but I can't get it working. PAP works fine but as soon as I change the connection setting back to ms-chap it fails with NPS error 66.
Hope someone has similar issues can point me in the right direction.
Cheers
Re: ms-chap airwave management authenication using 2008 nps
Did you configured the controller side to support mschap?
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
It's not actually a controller it's an airwave virtual appliance for network monitoring, but in there I selected ms-chap from the drop down in the radius setup and since then it doesn't work.
