- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
12-13-2013 09:47 AM
hi
i am not able to connect to airwave using https or http. the server is running and it is sending alert message. but i am not able to connect to the interface. any help on this will be appreciated.
Karthik
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-13-2013 10:50 AM
can you SSH as root to the server? Issue the command "daemons" There should be a long list. Try restarting them with the command "rd"
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: not able to connect to airwave
12-13-2013 10:53 AM
Though restarting daemons is like hammering your way through the problem. If you want to debug and find out the cause, it'd be worth opening a case with support. Any crashes in the apache logs (/var/log/httpd/error_log or access_log)?
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-13-2013 11:13 AM
[root@bhusd mercury]# daemons ?
PID PPID PGID %CPU %MEM RSS ELAPSED CMD
1751 1 1750 0.3 2.9 232644 20:06:52 VisualRF
1464 1 1464 0.0 0.1 10912 20:08:11 Daemon::LowLevelServiceWatcher
1521 1 1478 0.0 0.0 504 20:07:55 msgHandler
1164 1 1164 0.0 0.0 1640 20:10:39 rrdcached
1738 1 1738 0.0 2.9 230716 20:06:53 snmptrapd
i dont see a long list just the above
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-13-2013 11:17 AM
What is the output of # df -h
i guess the server is out of disk space
-s
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-13-2013 11:17 AM
It would seem that none of the other daemons are currently running on your server. Check to see if the disk drive of the AMP is full:
# df -h
If it's not, then doing the 'rd' that Seth suggested could possibly get you back up and running. But the fact that apache/pound are not visible explains why the UI was unreachable. There may be better clues to the outtage in /var/log/low_level_service_watcher or service_watcher logs.
Rob Gin
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-13-2013 01:52 PM
[root@bhusd mercury]# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/VolGroup00-LogVol00
65G 14G 48G 23% /
tmpfs 3.8G 0 3.8G 0% /dev/shm
/dev/sda1 97M 36M 57M 39% /boot
have enough disk space
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-13-2013 01:56 PM
Did you try 'restart daemons' ('rd' command) already? If not, go ahead and do so and open a support case to see if they can help find the root cause.
Rob Gin
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
12-13-2013 02:28 PM
i did and below is the output
and also i am able to connect to the interface .. thanks a lot for the help...and how do i enable autoboot...i restarted the server before running rd.. but the server is not doing autoboot. it stops in the boot prompt then i need to press enter to boot..please help me on this too.
2218 1 2218 0.0 0.2 18716 02:08 airbus
1924 1 1924 33.7 10.4 820716 03:18 httpd_
2212 1 2212 1.1 10.3 815392 02:09 Daemon::ServiceWatcher
2220 1 2220 0.0 10.3 814092 02:08 Daemon::PortGrabber
2223 1 2223 0.0 10.3 814036 02:07 Daemon::TupleSpaces
2226 1 2226 0.0 10.3 814092 02:07 Daemon::TupleScheduler
2254 1 2254 0.0 10.3 814692 02:06 Daemon::SwarmHandler
2272 1 2272 0.3 10.3 814984 02:04 Daemon::PerfCollector
2276 1 2276 0.0 10.3 813776 02:04 Daemon::AlertD
2283 1 2283 0.9 10.3 815404 02:03 Daemon::APListCacher
2286 1 2286 0.0 10.3 814520 02:03 Daemon::APScanner
2289 1 2289 0.0 10.3 813872 02:03 Daemon::APWatcher
2293 1 2293 0.0 10.3 814044 02:02 Daemon::APWatcherPollNow
2296 1 2296 0.0 10.3 814580 02:02 Daemon::AsyncLoggerClient
2299 1 2299 0.0 10.3 813784 02:01 Daemon::ConfigPusher
2306 1 2306 0.0 10.3 814048 02:01 Daemon::ConfigVerifier
2310 1 2310 0.0 10.3 814512 02:00 Daemon::DeviceEvent
2317 1 2317 0.0 10.3 814072 02:00 Daemon::DNSFetcher
2333 1 2333 0.0 10.3 814020 01:59 Daemon::PartialConfigPusher
2336 1 2336 0.0 10.4 818936 01:59 Daemon::PAPI
2339 2336 2336 0.0 10.3 814464 01:59 Daemon::AMONAggregator
2375 1 2375 0.0 10.3 813812 01:54 Daemon::SNMPEnabler
2378 1 2378 0.0 10.3 814076 01:54 Daemon::SNMPFetcher
2384 1 2384 0.0 10.3 814952 01:14 Daemon::SNMPV2Fetcher
2387 1 2387 0.0 10.3 814952 01:14 Daemon::SNMPV2Fetcher
2390 1 2390 0.3 10.4 817704 01:14 Daemon::SyncD
2397 1 2397 0.0 10.3 813812 01:13 Daemon::WepKeySetter
2437 1 2437 0.0 10.3 815408 01:11 Daemon::AsyncLoggerClient
2395 2394 2394 25.7 2.1 169708 01:13 VisualRF
2200 1 2200 0.3 0.1 10268 02:12 Daemon::LowLevelServiceWatcher
2257 1 2212 0.0 0.0 504 02:06 msgHandler
2266 1 2266 0.0 0.0 900 02:04 pound
2268 2266 2266 0.1 0.0 4332 02:04 pound
2366 1 2366 0.0 1.0 85668 01:54 radiusd
1115 1 1115 0.0 0.0 1196 06:30 rrdcached
2382 1 2382 0.0 2.9 230600 01:14 snmptrapd
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
