Network Management
Frequent Contributor II
run a command from Airwave not working when local controller auth-mgmt disable
I recently disabled local management authentication on our controller as we wish to use TACACS+. Since then, when I try to use the "run a command" function in Airwave,  Airwave is unable to login to the controller.
Is there a way around this so that I don't have to enable local management authentication on my controllers ?
Re: run a command from Airwave not working when local controller auth-mgmt disable
create an account in Tacacs that Airwave can use.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
