Network Management
kmd
Contributor II
secondary iphelper
Hello.
I going to add a 2012 r2 failover dhcp server on my domain. I am using an S2500 for routing. Can someone please tell me what would be the command for adding a second iphelper to my router?
Thank you
Re: secondary iphelper
Simply add another address to your helper-address profile.
Tim Cappalli | Aruba Security
