- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
shutdown airwave
shutdown airwave
03-22-2018 06:46 AM
Whtas the difference between
shutdown -h now
and
shutdown -p now
i think both just shutdown the airwave but whtas the diference?
Cheers
Carlos
Alternetworks Corp
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: shutdown airwave
03-22-2018 09:35 AM
Hey, I believe they should be the same as the Linux/Unix commands:
-h will halt after shutdown and terminates all processes and shuts down the cpu.
-p is poweroff and is exactly like halt, but it also turns off the unit itself (lights and everything on a PC). It sends an ACPI command to the board, then to the PSU, to cut the power.
Is the AirWave running on CentOS?
ACMA, ACMP, ACSA
If my post addresses your query, give kudos:)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-22-2018 10:45 AM
Yes, airwave runs on cent os
My question would be if i wanted to shutdown the airwave which of the two i shoudl use?
I think i have tried both and both seems to do the same but well which one would be recommended?
Cheers
Carlos
Alternetworks Corp
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-23-2018 01:55 AM
As mentioned both works same only differnece is -p poweroff the lights aswell.
If you want to complete remove the server from network and want to ship to different place then use poweroff, else halt is fine.
Pavan
If my post address your queries, give kudos and accept as solution!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-23-2018 05:37 AM
Okay
Well i got a virtual server of airwave, and we are doing a maintenience to the physical server so we need to turn it off.
In thi case halt(shutdown -h now) is fine? or do i need to poweroff(shudown -p now)?
Cheers
Carlos
Alternetworks Corp
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-23-2018 07:26 AM
ACPI in the BIOS should already be enabled. So halt and poweroff should be doing the same thing. You could also call the shutdown from the AMPCLI: Advanced (8) -> Shutdown (6)
AirWave Management Platform 8.2.6 on airwave.lab.com
1 Upload File
2 Download File
3 Delete File
4 Backup
5 Restore
6 Support
7 Upgrade
8 Advanced
9 Security
10 Custom Commands
11 Enter Commands
q >> Quit
Your choice: 8
Advanced
1 Restart Application
2 Reboot System
3 Configure Network Settings
4 Set Hostname
5 Set Timezone
***6 Shutdown System (halt)***
7 Add the File Transfer User
b >> Back
This uses /sbin/halt which results in complete power off.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-23-2018 08:24 AM
its the same on airwave pre 8.2.4?
Cheers
Carlos
Alternetworks Corp
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
03-23-2018 08:37 AM
The AMPCLI cmd is introduced in 8.2.4. If you're on an earlier version, both shutdown -h and shutdown -p should do the same thing. ACPI has been around for a while, so the server should be performing the full shutdown at this point unless the hardware is 10yrs or older.
Rob Gin
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
