Network Management
topology feature airwave
Hello
I m using topology feature in airwave and im trying to move around hte switches on the map so i can understand it better, if i use the pin devices, i can move it and its all good, but whenever i go to another tab let say i go to another tab, for example clarity tab, and go back to topology tab, all the swithces that i moved are go back  like if i didnt move anything...
Is there a way to safe it? so the swithces that i move on the map stay where i leave it???
Cheers
Carlos
Alternetworks Corp
Re: topology feature airwave
i just saw this tread  that asnwer my question
https://community.arubanetworks.com/t5/Network-Management/Airwave-8-2-5-Topology-map/td-p/323406
Alternetworks Corp
