Network Management
Contributor I
trying to upgrade from 8.2.2 to 8.2.3.1
having issues going from 8.2.2 to 8.2.3.1.
error: open of ../node_js/npm/openssl-devel-aruba-1.0.2h-1.el6.x86_64.rpm failed: No such file or directory
make[3]: *** [security_patches] Error 1
make[3]: Leaving directory `/root/git/mercury/src/x86_64/rpms/CentOS-6'
make[2]: *** [perllib] Error 2
make[2]: Leaving directory `/root/git/mercury/src'
make[1]: *** [src_install] Error 2
make[1]: Leaving directory `/root/git/mercury'
make: *** [upgrade] Error 2
make: Leaving directory `/root/git/mercury
Really starting to get bugged with this update issues.  CentOS is current final version 6.8. there are no OpenSSL updates.  I am not sure if the problem is with perllib or not.  I am downloading 8.2.2.1 and 8.2.3 now to try stepping up to each version in between. Currently running 8.2.2.
Yum reports there is no perllib package to install.
Re: trying to upgrade from 8.2.2 to 8.2.3.1
Share complet upgrade log from /var/log/upgrade directory and below outputs
#root;amp_version
#root;git show
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Contributor I
amp_version = 8.2.2
git show: command not found.
See the attached log.
make[3]: Entering directory `/root/git/mercury/src'
error: Failed dependencies:
    fontconfig-devel is needed by (installed) gd-devel-2.0.35-11.el6.x86_64
    freetype-devel is needed by (installed) gd-devel-2.0.35-11.el6.x86_64
    libpng-devel is needed by (installed) gd-devel-2.0.35-11.el6.x86_64
make[3]: Leaving directory `/root/git/mercury/src'
/usr/bin/make -C /root/git/mercury/src/x86_64/rpms/CentOS-6 install_for_perllib
make[3]: Entering directory `/root/git/mercury/src/x86_64/rpms/CentOS-6'
CentOS release 6.8 (Final)
could you install below packages and recompile the code
# yum install fontconfig-devel-*
# yum install libpng-devel*
#root;make
Pavan
Contributor II
We have the same issue upgrading our Airwave.
  • Checked the /root directory and found that we have both SVN and GIT folder present and Airwave was trying to use SVN folder instead of GIT
  • Moved the SVN folder to /tmp directory
  • Went to the path /root/git/mercury and ran make to recompile the script
Hope this help, but please get an aruba Tac assist while doing this.
Edgar,
Solution you have provided is for when make fail to run from root prompt. If we have old svn and new svn file in same /root directory, make is failing. Moving old svn file to tmp directory and initiating make command works.
Issue here is not of make, it is caused due to dependecies, installing those dependencires will fix the issue.
Pavan
Pavan
Contributor I
I thought that originally but they appeared to be installed, Yum reports they are already installed and there is nothing to do.
Package fontconfig-devel-2.8.0-5.el6.x86_64 already installed and latest version
Nothing to do
Package 2:libpng-devel-1.2.49-2.el6_7.x86_64 already installed and latest version
Nothing to do
Have you tried recompile the code again? If yes and still throwing same dependencies error message then I beileve you are doing something wrong.
I would recommand to open TAC case to troubleshoot the issue further.
Regards
Pavan
Pavan
Contributor I
Well, I tried to go from 8.2.2 to 8.2.2.1 and got issues again.  So I opened a TAC ticket. thanks
