Network Management
Occasional Contributor I
upgrade priority between airwave and aruba os?
I have to upgrade 2 master/local controller and an airwave server.  Is there a risk/preference of upgrading one before the other?
Re: upgrade priority between airwave and aruba os?
Are you managing your controller config in AirWave?
Tim Cappalli | Aruba Security
read-only mode
Moderator
I typically suggest upgrading AirWave first.  The reasoning is that if the firmware is newer than supported, then you may see some false-positive errors from the AirWave until AirWave system upgrade (depending on what triggers/alerts you have configured).
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
