Network Management
Trusted Contributor I
using SNMP to read information FROM airwave
don't ask me why, but is it possible to read the data from airwave with SNMP? i searched through the documentation and airheads but looking for SNMP usually turns up information about the other way around :)
Re: using SNMP to read information FROM airwave
Are you trying to get AirWave data or data from the linux platform below like cpu load, memory, etc?
Tim Cappalli | Aruba Security
the main goal is airwave data, linux platform would be a nice side catch.
Moderator
This sounds and feels like feature request material.
AMP can send SNMP traps (AMP Setup -> NMS tab), but this is to an external NMS with limited mibs.
An alternative might be to use the APIs (Home -> Documentation -> State and Statistical APIs).
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
i don't need it that badly, just checking the posibilities.
ill keep the API in mind if i really need it, for now ill just leave it, thanks for the info
Contributor II
Is it possible?.
I would like to monitor Airwave cpu load, memory etc status from Nagios and i don´t find how to configure it.
